Author Topic: Vr6 radiator help needed  (Read 1557 times)
Offline luke
  • When in doubt, whip it out!
« on: 09 January 2013, 20:22 »
Mk2 is going in the garage for a few months so thought I'd treat myself to an obd1 95' vr6, unfortunately the radiator is leaking, and was wondering if its just golf vr6 rads that fit and where I can find a cheap one, next question is will my mk2 coilovers fit the vr?
Muchos gracias in advance
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
Offline Screech16v
  • MK3 20vt AGU
Re: Vr6 radiator help needed
« Reply #1 on: 09 January 2013, 20:33 »
Gti outlets come out the same side if you flip the rad but the thermo switch is on the other side so guess its a vr only thing,sure ive seen new ones for around 30 so not to bad,coilovers will fit but you may need to change the top mounts over
Offline luke
« Reply #2 on: 09 January 2013, 20:36 »
Cheapest so far I can find on the Internet is above £100, and also on the rear they are kw coilovers but have leaked all the oil and are stiff and bumpy so don't want a bumpy ride
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 09 January 2013, 20:47 »
Just had a quick look on the bay and found this one,not 30 but not 100 either,looks like vr rad shares with other models looking at the listing
Offline tweed
« Reply #4 on: 09 January 2013, 21:34 »
I think all twin fan rads are the same gti 8v gti 16v and vr6.
Also plenty of vr's been broken up, what's wrong with used?
Offline luke
« Reply #5 on: 09 January 2013, 21:35 »
Not bothered whether new or used, just need something for if for next weekend when I bring it on the road and the mk2 taking its place in the garage
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 09 January 2013, 21:46 »
Im running a vr rad and it was different to my leaky gti one, if you can do used theres loads of cheap ones about
