Author Topic: It's a mystery - Damp boot carpet?  (Read 1227 times)
Offline N4SOP
« on: 08 January 2013, 23:31 »
Over the past couple of days I've noticed a nasty damp smell inside the golf. I checked for rotting food, gym clothes tucked away etc but all became clear when I opened the boot. The carpet was really damp but there was no signs of water coming in.
So yesterday I take the car through a car wash with the back seats down and a torch in hand. No signs of water coming un although there were large droplets forming on the plastic panel which attaches to the boot lid (passenger side) Once I got home I removed the panel but behind it was bone dry!?!?!
Any ideas?
Offline barrym381
Re: It's a mystery - Damp boot carpet?
« Reply #1 on: 09 January 2013, 00:07 »
does your rear washer work  :smiley:
Offline N4SOP
« Reply #2 on: 09 January 2013, 01:19 »
Actually, no it doesn't because the last owner decided to cut the hose when he replaced the boot lock!
I've plugged it, so it shouldn't be the cause.
Offline mcgee9t2
« Reply #3 on: 09 January 2013, 09:48 »
Theres a vent in the boot i think. belive its under one of the lights behind the bumper but not sure. my first port of call would be checking that. beleive theres a thread on ukmkivs showing were it is how to get to it ect.
Offline N4SOP
« Reply #4 on: 09 January 2013, 11:22 »
Thanks for the info. I'll look into it :)
Offline bonny
« Reply #5 on: 09 January 2013, 20:00 »
Will be vents like mine was  :shocked:
Left side
Right side
Either get new vents from dealers about £12 each & seal them in place or just try & seal them 1st & see how you get on  :wink:
Bumper & back lights off for easy access ftw  :smiley:
The more you pay The faster you go.....
Offline tomparkes
  • OEM+
« Reply #6 on: 10 January 2013, 14:03 »
Lift the carpet up and take the spare wheel out - you might find you've got a swimming pool in your boot! I've got a leak in my boot but can't exactly pinpoint it at the moment - definitely check those vents though as they're a common problem. Once it's warmed up a bit and we get a few dry days I'm going to take mine to pieces and try sealing everything up. There's a load of threads on this forum about "condensation", "water leaks", etc. which I read through and they all point towards these bloody cabin vents. I think you can use plumbing sealant, which you can get from B&Q or somewhere (might be worth having someone clarify this though as I haven't done it myself). Mk4's seem to be prone to leaks unfortunately :cry:
EDIT: Just remembered this: http://uk-mkivs.net/forums/t/51109.aspx
« Last Edit: 10 January 2013, 14:10 by tomparkes »
2004 1.8T AUM | CM Silicone Hoses | Pipercross Panel Filter | Smoothed Stock Airbox | Weitec Ultra GT -40mm Springs & Shocks | Genuine 18" Anni BBS RC's | Anni GTI Front Grill Badge | Sharan Rear Badge | Polo Stubby Aerial | Black Centre Console
My Build Thread
