Author Topic: Help identifying 2 pin connector  (Read 1403 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 22 July 2005, 09:38 »
om my 16V K jet engine, there is a two pin connector in the engine i need to identify what is does and for -
It's the (brown) one below the water outlet on the block under the middle of the three temp senders! it's kinda hidden from normal view because of the water pipe!
Judderi
Re: Help identifying 2 pin connector
« Reply #1 on: 22 July 2005, 09:39 »
Sound like the warm up regulator.Can you get a pic?
Offline Deefadog
« Reply #2 on: 22 July 2005, 10:11 »
It not the WUR! it's to the right of the WUR is the water hose and it's behind that going straight into the side of the block, i'll try and get a pic, but it will be difficult :)
Judderi
« Reply #3 on: 22 July 2005, 10:13 »
Might be the knock sensor, but that is a guess!
Offline Deefadog
« Reply #4 on: 22 July 2005, 10:25 »
Cheers, what does the knock sensor do? i'll get pics later :)
Judderi
« Reply #5 on: 22 July 2005, 13:32 »
Not sure exactly. I know it detects knocks to the engine and cuts the revs. Not sure why though. Might be a safety feature to cut the engine in a crash?
« Reply #6 on: 22 July 2005, 13:57 »
Knock sensor detects when the engine is pinking and retards the ignition timing until it stops. I'm 99.9% sure you don't have one on your 16v, AFAIK its only fitted to engines with Digifant management systems.
Offline Deefadog
« Reply #7 on: 22 July 2005, 14:06 »
I thought i may not have one :)
Any idea what that connector is for? i know it's difficult to explain without a pic! I am guessing it must be some temp sensor as it's in the block below the other thre temp sensors!
« Reply #8 on: 22 July 2005, 15:18 »
I have a gut feeling it might be the temp sensor for the ISV.  If not that all I can think of is a temp sender for the rad fan, some VWs have an extra circuit to switch the fan on if the block gets to a certain temperature.
Offline Deefadog
« Reply #9 on: 22 July 2005, 19:05 »
Cheers, i have been tryiong to remove it, just to clean it up, as i have done all the other connections, but the dam thing will not budge, because of the awkward postion i guess!
Any ideas on how i can find out exactly what it is? I have looked through the haynes but can't find anything!
