Author Topic: Changing mileage  (Read 1626 times)
Offline emery1990
Changing mileage
« on: 06 January 2013, 16:13 »
Just bought a Clio 182 off my mate but I need to swap the clocks as the rev needle is limp and hangs 1krpm too low. But as the mileage is digital how would you change it, is this just a garage job and cheap?
Offline Benrevs
Re: Changing mileage
« Reply #1 on: 06 January 2013, 16:19 »
I think it is stored on the ecu?
Offline tweed
« Reply #2 on: 06 January 2013, 16:42 »
How do you change it on a mk3 golf?
Offline Benrevs
« Reply #3 on: 06 January 2013, 18:13 »
Drive backwards for a while.. or drive forwards more?
Offline Seanl
« Reply #4 on: 06 January 2013, 19:52 »
There are specialists that can input correct milage on new clocks. Mk3 can be done externally (ie; on the clock itself whilst removed), but I would have thought newer cars would require to be done using diagnostic ports I would think.
Offline hobbiniho
« Reply #5 on: 06 January 2013, 20:06 »
yep digital mileage correction is easier than analogue its not illegal to alter the mileage of a car as long as you dont try to sell it on as that mileage being genuine but in the case of fitting new clocks and altering the mileage to suit theres nothing wrong with that
Offline emery1990
« Reply #6 on: 07 January 2013, 11:09 »
That's great then! Yeah thought ice seen it be done on tv before, saying how easily they can be clocked! Pretty good motor too the 182 I'm very impressed!
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #7 on: 08 January 2013, 15:04 »
With great ease if u have the correct equipment
Cost me £40 for mine doing and took the guy 5 mins
Clocks need to be out of the car, and before anyone says it vag tacho can't do It on a mk3
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline chrisr103
« Reply #8 on: 08 January 2013, 21:40 »
The MK4 & onwards is so easy to do, Also the same with most of the VAG Range  :shocked:
<a href="http://giffgaff.com/orders/affiliate/chrisr45" target="_blank"><img src="http://giffgaff.com/banner/01_80x15.png" width="80" height="15" alt="Get a free giffgaff Sim" /></a>
Offline tweed
« Reply #9 on: 09 January 2013, 18:23 »
Yeah I remember you saying a while ago now. He's far from me iirc?
Got a number or contact details?
