Author Topic: Matt's Accuair GTI - Now A MK5 R32!  (Read 113218 times)
Offline matttrance28
Re: Matt's Accuaired GTI
« Reply #40 on: 06 January 2013, 04:14 »
Air by Matty_Dub, on Flickr
« Reply #41 on: 06 January 2013, 04:14 »
Just a quick instagram photo[:P]
« Reply #42 on: 06 January 2013, 04:14 »
video of the rear ♥
http://www.flickr.com/photos/85799805@N04/8102670631/
need to get some new top mounts so i can drop it a little more [:)] would get some correction plates for the rear however they're not suited for air [N] so need to look down that route, also need to do some arch work on the front as the lip catches the tyre when dropped
« Reply #43 on: 06 January 2013, 04:15 »
Well I finally partly finished the install, firstly i put down some soundproofing
20121023_180111 by Matty_Dub, on Flickr
Found out why the speed sensor was faulty ..
20121025_174811 by Matty_Dub, on Flickr
20121025_175507 by Matty_Dub, on Flickr
Created a false floor
20121025_203210 by Matty_Dub, on Flickr
Received a helping hand to create the strut support for the air tank
20121025_215116 by Matty_Dub, on Flickr
20121025_215302 by Matty_Dub, on Flickr
Wired in the dimming function on the Controller, i now need to rewire it onto the headlights as its not getting enough power from the dimmer switch and pulses occasionally
20121027_111913 by Matty_Dub, on Flickr
False floor in, it has a grab handle too which is just slightly out of the picture
20121027_115210 by Matty_Dub, on Flickr
Strut fitment
20121027_115311 by Matty_Dub, on Flickr
20121027_115318 by Matty_Dub, on Flickr
Ignore the carpet for now, it's only temporary until i re-trim my whole interior
20121027_115424 by Matty_Dub, on Flickr
« Reply #44 on: 06 January 2013, 04:16 »
Went to the local meet had some pictures taken:
Needs to sit lower...
« Reply #45 on: 06 January 2013, 04:16 »
 Well sometimes even air doesn't help you:
after to dry up the oil:
Road kiss:
It's not too bad, could be worse, still ordering a new sump etc for the weekend, i did it as i left the carpark from work on my last day of redundancy, perfect way to go eh?
« Reply #46 on: 06 January 2013, 04:17 »
Taken on a friends camera as mine died, shame because the quality isn't that great and would've been some nice clear pictures  as we cant go back as the police moved us on nicely!
192429_10151308420011240_1525053987_o by Matty_Dub, on Flickr
135256_10151308419961240_867938812_o by Matty_Dub, on Flickr
52699_10151308419491240_2061769864_o by Matty_Dub, on Flickr
54619_10151308411861240_488903326_o by Matty_Dub, on Flickr
177371_10151308414351240_1386516593_o by Matty_Dub, on Flickr
665035_10151308411956240_2006222075_o by Matty_Dub, on Flickr
665397_10151308412601240_14352106_o by Matty_Dub, on Flickr
615422_10151308412731240_2115062335_o by Matty_Dub, on Flickr
680570_10151308412306240_998501135_o by Matty_Dub, on Flickr
« Reply #47 on: 06 January 2013, 04:17 »
Well i put the winter wheels on today
IMG_3382 ed by Matty_Dub, on Flickr
edit by Matty_Dub, on Flickr
« Reply #48 on: 06 January 2013, 04:18 »
Well here goes...
The other day when i reached into the back of the car to pick up a water bottle i thought oh balls.. my carpets drenched, then thought ah it's probably the water bottle has leaked.
On further inspection it was the drivers side foot well and rear passenger foot well(both driver side) were soaked, i then thought right it'l be the common door issue of it filling up and then filling the car.
I then took apart the drivers side door and couldn't see anything wrong, at this point i was stumped, so did a little research and a few posts on here related to checking the bonnet release grommet, so i did.
Unfortunately when separating the shuttle panel i snapped it, so I've repaired it temporarily with abit of plastic welding, and then loads and loads of JB weld around it, top and bottom, it looks nasty, but i'll be buying a new one to replace, it's sealed and does the job.
Shuttle panel during first stage of repair:
20121223_142017 by Matty_Dub, on Flickr
20121223_183123 by Matty_Dub, on Flickr
20121223_183117 by Matty_Dub, on Flickr
« Reply #49 on: 06 January 2013, 04:18 »
After the panel was removed i looked at the bonnet release grommet... needless to say the fitters (FAB FINISHING) have enraged me
20121223_155042 by Matty_Dub, on Flickr
20121223_155846 by Matty_Dub, on Flickr
So temporarily i needed the car on the road, so did a nasty bodge just so it sealed quickly.. (this didn't stay)
20121223_164335 by Matty_Dub, on Flickr
