Author Topic: Boost Leak? (Fixed)  (Read 3095 times)
Offline stfc_gti
Boost Leak? (Fixed)
« on: 05 January 2013, 10:43 »
So the past few days when im driving, when I give it some gas I can hear this loud whirring sounds, the more gas I give the more it whirs,
I have a forge 008 dv fitted and this is now no longer 'dumping'
I am a total amateur when it come to cars but im off outside to have a look for anything obvious, but any help would be great.
Its a mk4 gti aum
Thanks
« Last Edit: 14 January 2013, 10:11 by stfc_gti »
2002 1.8T GTI AUM, Standard (not for much longer)
Offline Dalo Harkin
Re: Boost Leak?
« Reply #1 on: 05 January 2013, 10:53 »
added or removed anythin recently?
boost leaks leak oil - so look for that  :wink:
Offline stfc_gti
Re: Boost Leak?
« Reply #2 on: 05 January 2013, 10:56 »
Think I have found it, will post a picture in a sec.
Offline stfc_gti
Re: Boost Leak?
« Reply #3 on: 05 January 2013, 11:00 »
I remember my mate telling me about this, he bodged it for me but said I needed to get it replaced. he said something about a breather pipe?
Offline stfc_gti
Re: Boost Leak?
« Reply #4 on: 05 January 2013, 11:08 »
that said, its only started happening a few days after I had a full service (cam belt, waterpump) etc etc. that breather pipe has been on its way out for a while, and although I have noticed a slight loss in mpg, there is no loss in power.
Offline stfc_gti
Re: Boost Leak?
« Reply #5 on: 05 January 2013, 21:07 »
the more I hear the noise, the less I think its a boost leak.
its like the whistling noise is coming from around the driver side of the engine towards the back/bottom.
the more I put my foot down the louder/faster it gets, if I ease off and drive at a steady speed, there is no whistle.
Offline Rhyso
Re: Boost Leak?
« Reply #6 on: 05 January 2013, 22:53 »
Check the pipe coming from the intercooler to the pancake pipe.  Its a common place for a boost leak and is located under the drivers wheel arch so would be around the area you are describing
Offline stfc_gti
Re: Boost Leak?
« Reply #7 on: 06 January 2013, 11:17 »
i'll do that today, thanks for the reply.
Offline Chris.
Re: Boost Leak?
« Reply #8 on: 06 January 2013, 11:38 »
What Rhyso said.  The push fit pipe is common to blow off.
Click For Build Thread
Offline stfc_gti
Re: Boost Leak?
« Reply #9 on: 06 January 2013, 17:47 »
Not had a chance to look yet but in my photo could someone give me the part number or name of the pipe that's split. It connects to the y pipe. Thanks
