Golf mk3
hardmonkeys
1.4 abd scanned following code found
Topic: 1.4 abd scanned following code found (Read 1416 times)
dubpirate
Here all the time
05 January 2013, 09:34 »
00515
what does this mean hall sensor or something
is this responsible for my running issues
thanks dan
dubpirate
Here all the time
Re: 1.4 abd scanned following code found
05 January 2013, 12:39 »
I did this with the engine off just ignition on but when I rescanned it with engine on it came up with no codes
Bellend
05 January 2013, 14:17 »
No fault code mate. That will come up with no engine running.
Where all my moneys went.
javalin
06 January 2013, 13:23 »
Thats:
http://wiki.ross-tech.com/wiki/index.php/00515
The engine is complaining about lack of signal from the hall sensor in the dizzy. Could easily be a running issue. Its either the sensor faulty or wiring
James
Last Edit: 06 January 2013, 13:26 by javalin
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Golf mk3
hardmonkeys
