Author Topic: Mk2 headache!!  (Read 2008 times)
Offline Brighouse-gti
Mk2 headache!!
« on: 04 January 2013, 23:41 »
Hello fellow dubbers!! Am here once again looking for help as I'm all out of ideas! Soooooo the story goes... I gets in me car other week to go to work and all I hear when I turn key is 'click'. Starter motor gone! So, no messing about, went out and bought a new starter same day and fitted it int evening. Job done, or not as it would seem! When I turned key to fire her up all I got was the same click sound as before! It would appear I've splashed out on a new starter for nothing!! Now she does still go, with a bump start so no locking up issues. Have checked all relevant wiring, earthing and all seems fine. Have even tested the new starter to be sure to be sure and alls good there. I get the feeling am missing something really simple. Does any one want to put me out my misery and suggest a, 'have you tried this'. Also it would be greatly appreciated as having to push me car down road every morning to get it to start is somewhat getting a bit embarrassing.  :embarrassed:
Thanking any suggestions in advance!!
Offline Lewy
Re: Mk2 headache!!
« Reply #1 on: 04 January 2013, 23:48 »
Relay?
Re: Mk2 headache!!
« Reply #2 on: 05 January 2013, 00:01 »
 :whistle: I have checked that, honestly  :whistle:
Offline Thom89
  • Looking for an "Icebreaker"
Re: Mk2 headache!!
« Reply #3 on: 05 January 2013, 00:16 »
Your car goes click, you fit a new battery :lipsrsealed:
Welcome btw
Thom
Offline devilscaff
  • allways up for alaugh
Re: Mk2 headache!!
« Reply #4 on: 05 January 2013, 09:19 »
Has to be a dud battery not holding any charge after being jump stated and driven
Re: Mk2 headache!!
« Reply #5 on: 05 January 2013, 09:51 »
I can definatly rule out the battery. Was new about 2 month ago, and have tested it too! Think I'll go down the relay route. Thanks for the suggestions tho!!   :grin:
Offline JC
  • Back in the North.
Re: Mk2 headache!!
« Reply #6 on: 05 January 2013, 09:58 »
next question, which relay  :laugh: :grin:
Offline Thom89
Re: Mk2 headache!!
« Reply #7 on: 05 January 2013, 12:14 »
Monies are still on the battery being flat.
Duff battery, especially if it was from Halfords, or something draining it, check bootlight, glovebox light, and radio are not drawing anything when the car is switched off
Faulty alarms and immobilisers, can also drain batteries
Thom
Offline oakgreener
Re: Mk2 headache!!
« Reply #8 on: 05 January 2013, 13:01 »
If it's a duff battery the voltage will disappear at the terminals when the starter is opperated.  Check that first. Usually the dash lights will go out and the clock will reset to zero if that's the case. Then check the voltage at the terminal wth the braided cable at the starter ( to earth). You should have a healthy voltage at this terminal. If the battery and starter motor are OK it's likely to be bad connection on the power side to the starter
Re: Mk2 headache!!
« Reply #9 on: 05 January 2013, 14:01 »
Thanks for the info, will check it out just to be sure. Well, I will next week, been called into work so she'll just have to sit at side of road till I get me hands on her again   :laugh:
