Author Topic: Rear coilovers creaking sound  (Read 1272 times)
Offline dubpirate
« on: 04 January 2013, 12:53 »
Ok so you have seen how low my mk3 was on the rear about 20mm from Morton of threads
So a couple of days ago I lifted it about 1.5 inch both sides on the thread
Not it has developed a creaking groaning sound when it's bumpy up and down
Any ideas peeps cheers dan
Offline dubpirate
Re: Rear coilovers creaking sound
« Reply #1 on: 04 January 2013, 12:56 »
They are only 5 month old
And it rode mint before no noises no catching
Offline Khare
  • The bear that khares
« Reply #2 on: 04 January 2013, 13:02 »
I had this on my Mk2. It was the plate between the main spring and helper spring. I used to spray mine with WD40 and it'd get rid of the sound for a while. You could try a thicker grease.
« Reply #3 on: 04 January 2013, 13:45 »
Or try new top mounts they can get noisy over time as they dry out.
Offline tweed
« Reply #4 on: 04 January 2013, 16:18 »
I also think top mounts.
When I changed my fronts I also lowered the coil overs another 15mm bottom of threads. Expecting it to be proper low when infact it was prob 5mm higher due to the old mounts fcuked
