General discussion
centre box
Topic: centre box (Read 3547 times)
Rain
forum irregular
Re: centre box
Reply #20 on:
22 July 2005, 19:07 »
nope
shouldnt move at all should be solid is it in and out movement or sideways
Mr Blue
Forum addict
Re: centre box
Reply #21 on:
22 July 2005, 19:17 »
if you think your CV's are f**ked then fut the steering on full lock and drive forward slowly. If you find that they click then they are probably dry or proper f**ked
Rain
forum irregular
Re: centre box
Reply #22 on:
22 July 2005, 19:32 »
knew there must have been an easiler way lol
VR6_ROB
Mk2 VR6 / Corrado G60
Re: centre box
Reply #23 on:
23 July 2005, 13:56 »
right i have the wheel off and i can move the drive shaft out of the wheel if u get me
i can get driveshaft 30quid fitted just gotta get caliper off but whoever had it before me
has rounded off bottom bolt on caliper so im tyrin to get that off which is bit fiddly
Rain
forum irregular
Re: centre box
Reply #24 on:
23 July 2005, 14:41 »
you might been to drill it its a common problem for them to snap most are snapped changing the pads although im sure there is an easier way ill have alook in a second.
Rain
forum irregular
Re: centre box
Reply #25 on:
23 July 2005, 14:45 »
you dont need to remove the caliper at all you just remove the ball joint by removing the bolt in the middle of the disc it should release it all, im goner check and make sure cause i watched a mate do it didnt know what i was doing.
VR6_ROB
Re: centre box
Reply #26 on:
23 July 2005, 14:50 »
to late lol i got caliper off need new pads anyway took disc off
cant get big nut out though dont hav big enough socket to fit it
so its sat on wood till tomoz
Rain
forum irregular
Re: centre box
Reply #27 on:
23 July 2005, 15:08 »
lol no worries look in mk2 section at the online bentlys it should have a picture of that section should have said that first :S
VR6_ROB
Re: centre box
Reply #28 on:
24 July 2005, 15:39 »
shockin really my cars sat on wood bottom of my drive i got promised a driveshaft
to be here and fitted today n i have not heard a peep not answerin phone either
so i am buggered for getitn to work tomorrow mot is 1st august aswell
General discussion
centre box
