Author Topic: centre box  (Read 3538 times)
Offline GTI EDITION (aka LTD)
Re: centre box
« Reply #10 on: 22 July 2005, 12:50 »
same thing cost me 200 notes for me mk3  :shocked:
My Vento (with the 8v 2E engine ) when my centre box went ( which was one of those heavy bu66ers ) I replaced it with the centre box from a mk3 1800 that I had to hand as the diameter was the same ,the box was lighter and straight through. which did improve the performance a bit :smiley:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline Overseer
Re: centre box
« Reply #11 on: 22 July 2005, 14:49 »
yeah the 16v middle box is a _much_ bigger diameter that the 8v.. they misfitted it wrong originally and they tried a 8v box when i took it back for a moan..
oh and i was running with a back box for a bit... sounded kick ass!!  :cool: :cool:
Hatchet Harry
Re: centre box
« Reply #12 on: 22 July 2005, 14:51 »
just cut it out and replace with a pipe.. it does fook all anyway really!
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
Re: centre box
« Reply #13 on: 22 July 2005, 18:24 »
i got a exhaust bandage for £4.25 done the trick
now i need a driveshaft as that went today :angry:
still runs but knocks n everything n shakes r these cheap
1 thing after another gettin sick
Offline Rain
  • forum irregular
Re: centre box
« Reply #14 on: 22 July 2005, 18:31 »
might just be the cv joints which arent expensive really dont know about drive shafts never heard of one going but knocking in the steering could be steering colum which are about £45 or over £100 for new/recon
Offline VR6_ROB
Re: centre box
« Reply #15 on: 22 July 2005, 18:39 »
It knocks when i go in straight line aswell at about 60mph when i take my foot off gas it stops
n it shakes like crazy
Re: centre box
« Reply #16 on: 22 July 2005, 18:43 »
Does yours have a balance weight on the o/s driveshaft as these can come adrift and rattle up and down the shaft or it maybe your inner CV joint that's bu66ered  :undecided:
Offline VR6_ROB
Re: centre box
« Reply #17 on: 22 July 2005, 18:45 »
well i dont no if this is unusual but i thought it was
wheel bearins so i pulled in at service station jacked up the side
where it was knockin n when i turned wheel it was gratin as it went round
dunno if it normally does drivers wheel was on ground as i did this
and can i tell if these things are buggered by lookin?
cheers
Offline Rain
  • forum irregular
Re: centre box
« Reply #18 on: 22 July 2005, 18:53 »
id go with that
 best way to check is lift the front either side and look behind the wheel there be a small shaft from the ball joint behind the wheel leading to the cv joint just check make sure there are no gaps or the bolts arent loose as this can also cause the same symptoms and is very common easiest way to check the steering is for play if driving in a straight line is you move it a few mill left or right the car should move in the correct directions if there is play and no response from the slightest of turns then its had its day.
Offline VR6_ROB
Re: centre box
« Reply #19 on: 22 July 2005, 19:04 »
i just been outside n i grabbed the passenger side shaft and i can move it in n out r they meant to move
