Author Topic: Clocks remove quick question  (Read 1086 times)
Offline dubpirate
« on: 03 January 2013, 08:41 »
Is there only 1x plug/connector going to the back of the clocks ie speedo and everything
Cheers dan
Offline sharki786
  • GOT BOOST??
Re: Clocks remove quick question
« Reply #1 on: 03 January 2013, 08:47 »
As far as i can remember there is only 1 plug
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Len
« Reply #2 on: 03 January 2013, 08:53 »
YES!
One big white plug.
The clocks come out easy enough if you drop the steering wheel.
www.sas.org.uk
www.the-ace.org.uk
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 03 January 2013, 09:36 »
When extracting the clocks from the dash be careful not to lose the rubber grommets that are on both of the bottom locating lugs as when you refit them they wont sit in place as snugly and may rattle.
