Author Topic: 1.8t running on 3 HELP  (Read 1573 times)
Offline BUDSY
« on: 02 January 2013, 18:37 »
I have a 2000 1.8 20v t i bought it yesterday and it was running on 3 so checked it over and found an electrode missing from a plug so i put a new set of plugs in it and everything was fine.
today it started running a bit lumpy so ive checked the plugs again but they are ok i checked the coil packs and found that its number 4 (furthest to the right) so swapped the coil packs and found that its not the coil pack either so its definatly number 4 but the plug and coilpack are both ok the wiring loom to the coil pack looks ok too
where do I go next please?
Offline mcgee9t2
Re: 1.8t running on 3 HELP
« Reply #1 on: 02 January 2013, 19:00 »
Scanned it for fault codes?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 02 January 2013, 19:04 »
what engine code
Offline Chris.
« Reply #3 on: 02 January 2013, 19:12 »
Where did your electrode go off the first plug is what id be asking!
Click For Build Thread
Offline wotavudunn
« Reply #4 on: 02 January 2013, 19:46 »
and me  :sad:
Offline BUDSY
« Reply #5 on: 02 January 2013, 19:48 »
electrode came off no1 but thats running ok i guess it got through the valve.
agu engine
and i dont have access to fault codes
i'm now thinking injector???? possibly
i just ran it up and was running on 3 then picked up no4 for a few seconds then 3 so took it out for a blast to maybe clear it but didnt
Offline barrym381
« Reply #6 on: 02 January 2013, 19:58 »
ignition amp sounds fu*ked :smiley:
Offline BUDSY
« Reply #7 on: 02 January 2013, 20:05 »
Ignition amp . . . i was lead to believe that when that goes it can take the coilpacks with it.
where is it mounted/ is it an easy replace?
Offline barrym381
« Reply #8 on: 02 January 2013, 20:08 »
its bolted to your air box im sure an its just a plug that connects it so easy to replace  :smiley:
Offline BUDSY
« Reply #9 on: 02 January 2013, 20:10 »
is it also called the ignition control unit found one on GSF?  sorry for all the questions and thanx for the help
