Golf mk3
hardmonkeys
Replacement Clutch
Topic: Replacement Clutch (Read 1571 times)
sdall30
GTI forum regular
Replacement Clutch
02 January 2013, 16:57 »
I'm putting a performance CAM in my MK3 8v GTI and will be replacing the clutch with an up rated version at the same time. I've settled on a "performance torque" product available from Larkspeed.
Problem is they list 2 stage ! versions for my model
this one
http://www.larkspeed.com/index.pl?p=DT238FR6408&a=i
and this one
http://www.larkspeed.com/index.pl?p=DT224FR6407&a=i
the only difference I can see is where it says in the description that one Fits Models with Manufacturing Code up to 306243 and the other Fits Models with Manufacturing Code 306244 .. what is the manufacturing code and how do I find out which one applies to my car so that I buy the correct clutch ?
Thanks for the help in advance
Stuart
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Replacement Clutch
02 January 2013, 17:00 »
Have a look at last six digits of your VIN....
VW BUSH
Guest
02 January 2013, 20:54 »
Why do you want a performance clutch, is it a track car?
tweed
Forum addict
02 January 2013, 21:22 »
I have a performance cam in my 8v and it does not need a performance clutch
struggles to wheel spin in the wet
Untitled
by
tweedub
, on Flickr
Screech16v
MK3 20vt AGU
02 January 2013, 21:32 »
A decent make clutch will be more than enough, luk or sachs
Wayne
Sir Postalot
03 January 2013, 00:01 »
Quote from: Screech16v on 02 January 2013, 21:32
^^This, Sachs or Luk will be fine.
Len
10k hero
Reply #6 on:
03 January 2013, 08:42 »
If he wants an uprated clutch in his car then let him.
Why do people on here give opinions the OP does not want?
www.sas.org.uk
www.the-ace.org.uk
Golf mk3
hardmonkeys
Replacement Clutch
