Author Topic: rear standard light coding help  (Read 6759 times)
Offline ajmoir36
Re: rear standard light coding help
« Reply #10 on: 02 January 2013, 20:24 »
Heres the coding from mine its a April 2010 I hope it can help.
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0575
   Revision: 00103 AG
   Coding: 48180A3A9825F1C044080080640001E443510088736D8560648000200000
   Shop #: WSC 01357 011 00200
   VCID: 3065EB90DA5F
   Part No: 1K2 955 119 F
   Component: Wischer 15031  21  0512
   Coding: 009795
   Part No: 1K0 955 559 AH
   Component: RLS 260310 05  54  0403
   Coding: 0330AD
   Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
No fault code found.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline ajmoir36
« Reply #11 on: 02 January 2013, 20:34 »
Although looking at this mine is set to 00 which maybe is no help if it is masking the original value. If its really massive problem I can always send them back to you (once of course parcel force delivery for a refund of course).
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #12 on: 02 January 2013, 20:53 »
There is a post on tise forum somewere that links to a pdf that lists the settings for all vw brand models. I think Mike posted it.
Garage:
35+ years of GTI ownership.
Offline ajmoir36
« Reply #13 on: 02 January 2013, 20:58 »
I believe from reading here you need to set it to 03 then 00. To make it back to stock look and operation. http://forums.vwvortex.com/showthread.php?4898893-LED-tail-Install-with-or-without-Rear-Fog./page2
Offline EyeballPaul
« Reply #14 on: 02 January 2013, 21:19 »
Aj,
Thanks, no real prob the car is getting part exed on the 12 th, just wanted it sorted by then, hopefully the dealer will sort it, they have raised a dis with VW UK. Otherwise it will go as is, i will just make sure i leave the lights on off. Hopefully u should get the LED,s tomorrow, enjoy. Mine certainly looks rubbish without them.
Offline ajmoir36
« Reply #15 on: 02 January 2013, 21:26 »
You have got me wondering what mine will need to be and I think for a 0575 module its 15.  But I am wondering the same issue of when that day comes what do i set it back too, if I can be bothered of course.  I have a VCDS so I can experiment, although I certainly dont want to brick my BCM9. Although I have read some posts that seem to suggest the newer module needs no coding for them to work ok.
Offline EyeballPaul
« Reply #16 on: 02 January 2013, 21:32 »
Your rite, when i fitted mine Stevep was surprised i didn't need a new bcm when he looked at the coding, as mine is an 09 car. Somehow i got away with it. Seems strange that a dealer cant sort it without having to raise reports to VW UK though.
Offline Buck
  • Das Auto
« Reply #17 on: 02 January 2013, 23:38 »
Paul
From memory you need to set it to 00 but you can't do this directly, you have to set it to say 15 first then to 00 and it'll keep it at that value.
Offline EyeballPaul
« Reply #18 on: 03 January 2013, 17:17 »
So what i can work out Byte 18 is the 18th pair of number or letter combinations from the left in the long code, not including the first 2 for some reason. I looked on the vw vortex forum and that seems to be how it works, just want to get it clear in my head when i go back to the dealers if they still are clueless in a day or so.
Offline Buck
  • Das Auto
« Reply #19 on: 03 January 2013, 17:32 »
^^Yes.
First set is Byte 00 then 01 so Byte 18 is the 19th pair.
