its the water pump working that circulates the water, the flow from the return pipe should increase as the revs are raised, They often work fine on idle but when using higher revs the impellor can spin on the shaft causing the engine to over heat, from reading threads on here it seems 60mph is where the problem seems to show, yours sounds water pump related,
