Author Topic: Mk2 gti 8v knock!!  (Read 2573 times)
Offline Jonoyorko
Mk2 gti 8v knock!!
« on: 01 January 2013, 12:18 »
Hiya again, after sorting out earth problems after installing engine,
It has now developed a knocking noise when I lift off acclerator and
when cornering at low speed is this engine mount failure??
any help much appreciated.
Thanks
Jono
Offline JimR
Re: Mk2 gti 8v knock!!
« Reply #1 on: 01 January 2013, 15:52 »
Any chance it could be a CV joint, knocking when cornering is a classic symptom.
Mk2 GTi.
Offline Jonoyorko
« Reply #2 on: 01 January 2013, 17:19 »
Just had CV joints done, more noticable when taking foot off accelerator
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 01 January 2013, 17:40 »
Check that the exhaust is not hitting the floor anywhere, and especially where it goes over the rear beam...
Thom
Offline Jonoyorko
« Reply #4 on: 01 January 2013, 18:12 »
Cheers Thom, just had that done last week,
Coming from front end for sure!
Offline Lewy
« Reply #5 on: 01 January 2013, 18:15 »
Hitting the bulkhead?
Offline Jonoyorko
« Reply #6 on: 01 January 2013, 18:21 »
Why would hit the bulkhead? Would a engine mount cause the knock?
Offline JimR
« Reply #7 on: 02 January 2013, 20:09 »
So many things it could be, knackered engine mount is one of them. Did you inspect them when you fitted the engine? Are the bolts done up properly? Go for a drive with a mate in the car to see if you can pinpoint better where the noise is coming from.
Mk2 GTi.
« Reply #8 on: 03 January 2013, 00:15 »
Sounds like a loose or knackered engine mount.
VW BUSH
« Reply #9 on: 06 January 2013, 16:50 »
I reckon Gear box mount
