Author Topic: Mobile disco all lights flash when indicating, FIXED THANKS  (Read 1340 times)
Offline mk2man1
Hi guys any ideas when indicating the fog light light on the switch flashes and so do all the indicators side lights and brake lights.Bad earth i think is there a common one that is a problem any ideas getting dangerous now thanks for any help
« Last Edit: 01 January 2013, 12:51 by mk2man1 »
The cost of living is going up and the chance of living is going down
Offline Screech16v
  • MK3 20vt AGU
Re: Mobile disco all lights flash when indicating
« Reply #1 on: 31 December 2012, 20:14 »
hi mate theres a few earths under the battery tray,battery out and four bolts hold the tray in probably have to unbolt the power steering res.
Offline trog_nfs
« Reply #2 on: 31 December 2012, 23:39 »
Id say water in the rear lights(s).
That would cause the symptoms you describe. Have a look and see if either of your rear lights have corrosion on the circuit board.
Offline mk2man1
I will take the light out today and check them out,any ideas why the interior light is now coming on all the time now.Starting to see why my bargain golf was such a bargain i have nearly spent out what the car cost me now.
Offline leigh_harty
  • Audi AGU
Mine did this, when i wiggled the plug it would fix itself  :smiley:
Dont lose your dinosaur!
Offline mk2man1
give it a bash is that the plug on the rear lights ,if i spend any more time on the golf i might get strung up.
Offline leigh_harty
  • Audi AGU
Yeah the plug on the lights, think I just have a bad connection. The earth points are right near the lights too give them a bit of sanding down  :smiley:
Offline mk2man1
Top man a simple wiggle solved the problem,but the earth on the plug socket going in to the cluster was scummed up too.
Thanks for your help
