Author Topic: Bad earth  (Read 996 times)
Offline asboGTI
Bad earth
« on: 29 December 2012, 12:49 »
As title says I have a bad earth as I can hear my car revving through my speakers anyone got any ideas where it most likely to be
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline asboGTI
Re: Bad earth
« Reply #1 on: 29 December 2012, 16:12 »
Bump
Offline navmk4gti
Re: Bad earth
« Reply #2 on: 29 December 2012, 17:11 »
Behind head unit. Thick brown wire is earth check is connected properly. Do you have an amplifer installed??
Offline asboGTI
Re: Bad earth
« Reply #3 on: 29 December 2012, 17:42 »
Everything standard ATM so I will check when I change the head unit would this be only one to cause these symptoms
Offline navmk4gti
Re: Bad earth
« Reply #4 on: 29 December 2012, 17:47 »
Yes mate its bad earth. If its not problem just behind headunit then it is going to be right pain folowing earth cable down to see where its fooked.
Offline asboGTI
Re: Bad earth
« Reply #5 on: 29 December 2012, 17:49 »
That's what I thought glad I was on the right lines if it's not fooled there I will have trace it as it will do my head in
Offline navmk4gti
Re: Bad earth
« Reply #6 on: 29 December 2012, 17:53 »
If you are gonna change your headunit do that First might solve it. If you get same On new headunit you know your earth needs checkin :wink:
Offline asboGTI
Re: Bad earth
« Reply #7 on: 29 December 2012, 18:34 »
Sweet cheers fella
