Author Topic: Not sure if its been asked but..  (Read 1814 times)
Offline Mark b
« on: 29 December 2012, 12:32 »
People sometimes talk about there engine I.e aum apk ect I'm prob gonna sound thick but where would I find my engine spec and do these have certain meanings ? Sorry if its a stupid question but still learning about my car as its my 1st golf I've owned
Standard gti 2.0 115bhp 2000 w reg
Offline Rob Zombie
Re: Not sure if its been asked but..
« Reply #1 on: 29 December 2012, 12:41 »
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline davemk4
« Reply #2 on: 29 December 2012, 12:43 »
Engine code stamped onto engine near front left side iirc
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Mark b
« Reply #3 on: 29 December 2012, 12:56 »
Cheers for the reply guys appreciate it was just curious ill have a look at my engine if it stops raining  :undecided:
Offline Rob Zombie
« Reply #4 on: 29 December 2012, 13:01 »
Is the the golf your currently have or have you now picked up a 1.8T ?
BHP: 231
TRQ: 251.7 lb-ft
Offline Mark b
« Reply #5 on: 29 December 2012, 13:53 »
It's the one I've got mine is a w reg mk4 gti 2.0 115bhp if that helps
Offline mcgee9t2
Offline Mark b
« Reply #7 on: 29 December 2012, 14:18 »
http://www.golfgtiforum.co.uk/index.php?topic=89491.0
Cheers for that just checked my book and its says APK does the apk have a meaning or is it just the name of the engine ?
Offline Pez
  • Golf IV - 2.8 v6
« Reply #8 on: 29 December 2012, 15:37 »
2.0   1999–2001   I4 8V   APK/AQY   1984 cc   85 kW (116 PS; 114 hp) @ 5200 rpm   170 N·m (130 lb·ft) @ 2400 rpm
2.0   2001–2006   I4 8V   AZJ/AZH   1984 cc   85 kW (116 PS; 114 hp) @ 5400 rpm   172 N·m (127 lb·ft) @ 3200 rpm
Offline rockmonkey69
« Reply #9 on: 29 December 2012, 17:05 »
170 N m is ~125 ft lb
Besides this, is the above accurate? It would appear there is a significant difference the rpm which they make peak torque.
« Last Edit: 29 December 2012, 17:09 by rockmonkey69 »
