Author Topic: Hesitation / misfire in bad rain  (Read 5078 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Hesitation / misfire in bad rain
« Reply #10 on: 30 December 2012, 20:34 »
Ah right ok,  mine never showed up a fault code and took bloody ages to diagnose  the first time around. Its a possibility then and definitely worth checking.
Offline Ashy
« Reply #11 on: 31 December 2012, 11:23 »
DOH totally forgot about vagcom, I'll give it a blast & report back
Offline Ashy
« Reply #12 on: 31 December 2012, 13:19 »
No faults shown apart from rear abs sensor which I knew about.
Not had a problem  since the rain...
Offline Khare
  • The bear that khares
« Reply #13 on: 31 December 2012, 13:27 »
Buy this
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_187211_langId_-1_categoryId_255221
I used to have some problems in the rain too. I used this and not had a misfire or hiccup since. This is only effective if what you're sealing has no damage in the first place.
Offline PS1801
  • Mk3 Golf GTi 16v
« Reply #14 on: 29 January 2013, 23:48 »
Mine has just started doing this, only when it's chucking it down or I go through a puddle, not happy, it just cost me £350 to get it through the MOT.... :cry:
I'll be checking the highlighted parts tomorrow, I put a second hand coil pack on it 18 months ago, wonder if it's also giving up the ghost!
Offline Khare
« Reply #15 on: 30 January 2013, 11:35 »
Most likely. I had bought a second hand coil after mine had started failing. Lasted 3 months or so before it started failing again! Bought a new one from RAC and it's been fine for over a year now.
Offline PS1801
  • Mk3 Golf GTi 16v
« Reply #16 on: 30 January 2013, 16:15 »
When the coil pack failed last time it stalled and wouldn't start again, this time it stalls and starts after 2 or 3 mins, or doesn't completely stall but you get a bit of hesitation..... I'll be having a look on Saturday to see if the crank sensor is at fault too.   :wink:
Offline boneybradley
  • Back in a Mk3...
« Reply #17 on: 30 January 2013, 18:40 »
keep some wd40 in your car and next time it misses in the rain, spray each part until it stops. the last part sprayed is your fault
(b.t.w if it's not wet damp related it won't help)
Offline stow1985
  • 'when im cleaning winders'
« Reply #18 on: 30 January 2013, 21:46 »
Buy this
Interesting stuff, how do you use it??
My money is onthe coil
Offline Khare
« Reply #19 on: 30 January 2013, 22:14 »
wipe any dirt off the components and then just spray it over them. Coil, distributor, HT leads, battery clamps and any other exposed electrical connections, including plugs if you want. What it does is it creates like a very thin flexible plastic layer and protects the components from water ingestion. Since using it I have had 0 problems in the wet.
