Author Topic: Hesitation / misfire in bad rain  (Read 5079 times)
Offline Ashy
« on: 28 December 2012, 20:39 »
Hi
Did a lot of miles over christmas period.
on the way back up the M1, after 3 hours of driving in torrential rain, holding 70 ish. had a few moments of hesitation or maybe misfiring.
Not had any problems like this before.
happened about 15 times, just a split second of hesitation and then back to normal.
Standard mk3 8v with drilled airbox.
anyone got any ideas  or suggestions please?
Thanks
Offline Screech16v
  • MK3 20vt AGU
Re: Hesitation / misfire in bad rain
« Reply #1 on: 28 December 2012, 20:48 »
Coil is a favourite maybe ecu relay 30
Offline tweed
« Reply #2 on: 28 December 2012, 21:12 »
Relay 30?
It's a water problem. Wouldn't at all be surprised if water got in the dizzy.
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 28 December 2012, 21:36 »
Just because it was raining and this fault occured doesn't mean the fault is defo water related  :whistle:
Offline AshyGTI
« Reply #4 on: 28 December 2012, 22:46 »
First time I've really drive it in the rain.  Well monsoon conditions anyway.
Will have a look at those parts
Ta
Offline CJA321
« Reply #5 on: 29 December 2012, 02:54 »
Id have a stab at the coil
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 29 December 2012, 10:09 »
Coil, lead and plugs is where I'd start.
Offline javalin
« Reply #7 on: 29 December 2012, 21:39 »
Worth checking the crank sensor wiring - its under the oil filter kinda area.  Common to see the insulation break down (aka fall apart) and then the rain/spray/puddle cause issues.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #8 on: 30 December 2012, 10:59 »
Although from my experience of dodgy crank speed sensors is that the engine will cut out completely,  not misfire.
Offline Khare
  • The bear that khares
« Reply #9 on: 30 December 2012, 17:41 »
From mine it can misfire. Insulation was all good, but the sensor bit that peeps inside the engine had a small crack in it. The only reason I knew it was the crank sensor was because it came up on vagcom as intermittent fault.
