Author Topic: 2000 VW Golg 2.0 GTI APK engine - excessive fuel consumption  (Read 1450 times)
Offline jimmylee
Help.
I have the above car and my fuel consumption has gone through the roof !!
I am getting about 15 miles from £20 of fuel !!!
I have changed the following :
Air Mass Meter
Coolant temp sensor
Thermostat
spark plugs
The emmissions on CO2 ( supposed to be 0.3%) is reading 23.9%
the engine also idles erratically and smokes
Offline Screech16v
  • MK3 20vt AGU
Re: 2000 VW Golg 2.0 GTI APK engine - excessive fuel consumption
« Reply #1 on: 28 December 2012, 16:59 »
Have you scanned it for fault codes or cleared old ones from changing parts?
Offline opel
« Reply #2 on: 28 December 2012, 18:32 »
you sure you aint got a leak as that alot of fuel for 15 miles
Offline Chris#101
« Reply #3 on: 28 December 2012, 19:04 »
Any fault codes? Lambda sensors?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline ReDBull
« Reply #4 on: 28 December 2012, 19:58 »
My pre cat Lambda has died and the MPG has dropped by 5-10 mpg but that is a lot! If it's over furling that much you'll kill the cat and end up with bore wash! I'd get it looked at before you drive much further.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
« Reply #5 on: 28 December 2012, 23:38 »
Stop using it and get it checked asap, sounds like you have a leak.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 29 December 2012, 20:35 »
There is something seriously wrong to have a CO2 reading of 23.9%. As above you'll knacker the cat, plugs and the engine with that sort of fuel going through.
« Reply #7 on: 29 December 2012, 23:54 »
Could be the ECU has blown and it is dumping fuel into the engine.
