Author Topic: Grrrrrrr cut out again.  (Read 4359 times)
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« on: 28 December 2012, 14:23 »
Hi guys need some help please.Drove the car into town and got stuck in traffic,went to move off and car cut out.Wouldn't restart so left it for 20 minutes and it started ok.This is the second time it's happened in 2 weeks and always when the oil temp gets to around 75 degrees.Had the crank sensor changed so i know its not that.
Any ideas.
Rob
Offline GOLF-MK3-GTI
Re: Grrrrrrr cut out again.
« Reply #1 on: 28 December 2012, 14:50 »
Any ideas.
Rob
When you say it cut out, Did it just lose all power?, Did the revs go all over the place?
Could be ECU Relay?
Offline dixie180
« Reply #2 on: 28 December 2012, 14:55 »
Hi.Just cut out and revs just died.Didn't have the flashing oil light syndrome either.It only cuts out when oil temp gets to about 75 degrees.I changed ECU relay and the car ran worse so i put the old one back in.
Rob
Offline Luke1981
« Reply #3 on: 28 December 2012, 15:00 »
The car shouldn't run worse with a new ecu relay. Did you purchase OEM? Relay number 109
MK IV GT TDI 150 PD / MKII CADDY SDI
« Reply #4 on: 28 December 2012, 15:04 »
Have u tried a new ECU Temp sensor?? Try starting it with this plugged out?
« Last Edit: 28 December 2012, 15:11 by GOLF-MK3-GTI »
Offline dixie180
« Reply #5 on: 28 December 2012, 15:11 »
Yeah ECU relay 30 and new one is white,the old one which is still in the fuse box is black.Where is the ECU temp sensor.The only temp sensor i know of is in front of the block above the oil filter ?.Sorry forgot to say new one is from VW.
Rob
« Reply #6 on: 28 December 2012, 15:13 »
Rob
It on-top of the water flange, the one which is infront of the engine block, Its got a 4 pin connector
Offline dixie180
« Reply #7 on: 28 December 2012, 15:15 »
Yeah changed that and its original VW.Always had a problem with the temp not sitting at 90 but have put that down to worn thermostat.
Rob
« Reply #8 on: 28 December 2012, 15:16 »
touch the relays after driving the car for 10-15 mins, they should be warm to touch, if they are cold, you then have a duff relay.
The fuel pump relay is also common to naff up, Keep an eye on them.
« Reply #9 on: 28 December 2012, 15:18 »
Have you had the car on VAG-COM?? to see if any faults are showing up??
