Author Topic: Wiring for stereo to come on with ignition  (Read 1413 times)
Offline dubpirate
« on: 28 December 2012, 08:51 »
Hi
The car is a 1.4 abd 1993
I want the radio to come on and go off with the ign
Can someone tell me how to wire this please an which wires which
I tried for hours to get the correct combo yesterday
But I can only get it hard wired to the battery so its on and off manually
Help please
Offline bored_Welsh_lad
Re: Wiring for stereo to come on with ignition
« Reply #1 on: 28 December 2012, 08:54 »
You should have a red and yellow wire on the loom for the stereo, I believe the red is the perm live and the yellow is ignition live. Yellow and red together can give you perm live when ignition is off, what I have found with some stereos is that the yellow and red seem to be the wrong way around. They are normally on bullet connectors so try swapping them if that makes sense..
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline dubpirate
« Reply #2 on: 28 December 2012, 09:28 »
I don to have red and yellow wits in the car loom and the cars scocket has been previously cut off
I have red and white
Blue
Ble and white
Brown and red thin
Brown thick - earth
What else am I looking for
Offline vwwvgolf
« Reply #3 on: 28 December 2012, 11:50 »
Try search for the make and model s manual on google. Might be able to find it. Or there is car audio section?
« Reply #4 on: 29 December 2012, 09:28 »
http://www.golfgtiforum.co.uk/index.php?topic=74087.0
Wiring diagram is half way down. I thought you were trying to fit a stereo with ISP blocks. Sorry. The diagram should show you the wires you need.
Bumper Vents :D
Offline dubpirate
« Reply #5 on: 29 December 2012, 09:40 »
ok so looking at this diagram I have merged the brown and red which I believe is ign live with the red cable back of head unit
and the white and red which I believe is constant batt to the yellow cable back of head unit
it will not come on with the ignition
then I have swapped them over with the bullet connectors in the yellow and red harness in the back of the head unit
still will not work but flashes as I turn ign off?
only way I can get it o work at all is by merging them all
but its constant not run from the ign which I want
Offline itavaltalainen
« Reply #6 on: 29 December 2012, 13:19 »
red-white is perm. 12, brown-red is ign 12...
http://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=710597
You should not combine red-white and brown-red on car loom...
Check with a multimeter if you get voltage on brown red with ignition on, if not then you gotta work your way back to the ignition and check up to which point you've got juice....
Offline dubpirate
« Reply #7 on: 29 December 2012, 22:36 »
its the only way the head unit would work
I tried al sorts of separate combos
