Golf mk4
Golf mk4 TDI
Wazzzer
Correct drive belt for this TDI
Topic: Correct drive belt for this TDI (Read 2348 times)
NotMyName
GTI forum regular
26 December 2012, 23:03 »
2002 plated 1.9 TDI 100bhp with Aircon
Just to double check - is this the correct belt required:
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_1.9_2002/p/car-parts/engine-parts/belts-chains-and-tensioners/car-drive-belt/?202441175&1&8d4ba3fb906900ad8e274c2ca1de96f1b5fbeb8b&000108?
It couldn't possibly be any other belt?
The belt itself has snapped. Would anything else be required? I'm quite positive that it was replaced only a couple months ago, or it might've just been the tensioner, though i'm sure the belt was done as well. Either way it was my brother who changed whatever it was & not a proper mechanic. He rags the car to death if this is likely to have an impact on the snapped belt.
If the tensioner was replaced the other month, would you still replace it in this case or leave it?
EsSeX dAn
Re: Correct drive belt for this TDI
27 December 2012, 22:29 »
should be ok so long as the car has air conditioning. leave rhe tensioner if it was swapped recently
i think i love you.....
NotMyName
GTI forum regular
29 December 2012, 15:44 »
Here we go. Any takers on this.?....
So he got picked up by the AA last night (make use of the breakdown subscription!). They cut the belt off.
He's fitted his old belt today for temporary purposes (& because he's an impatient sod). He said that the grooves on the belt don't line up fully with the tensioner pulley. The way he was describing it was making it sound like most of the belt is over the pulley, but the edge of the belt isn't - therefore the edge of the belt is not taught.
Because of this he questions the quality of the tensioner bought last time round, which was this one:
http://www.ebay.co.uk/itm/GOLF-MK4-1-9-TDI-00-05-OE-QUALITY-AUX-RIBBED-DRIVE-FAN-BELT-TENSIONER-/150814014282?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D4456905106092512277%26pid%3D100015%26prg%3D1006%26rk%3D1%26sd%3D150814014282%26
Golf mk4
Golf mk4 TDI
Wazzzer
