Author Topic: How many mounts does the 1.8 have ?  (Read 1293 times)
Offline spudboy6
  • Just like a golf ......
« on: 24 December 2012, 21:32 »
Not at the car right now and wondering how many mounts does it have on the 1.8 8v
I know obviously front (I've pucked it )
Gear box ( any good stiff mounts or pucks or genuine? )
And are there any more mounts ? I'm sure there's one more .
Only reason I ask it when I change gear I get a knock , does it when letting clutch up and getting power down . Recently changed the front mount , and I believe the box mount is full of oil/grease ? And seen it leaking if so .
Thanks guys and girls and merry crimbo
Offline DCmk3
Re: How many mounts does the 1.8 have ?
« Reply #1 on: 24 December 2012, 22:13 »
Front, Gearbox and rear next to the exhaust manifold.
And yes, the gearbox mount is oil filled. I would suggest replacing it if it is leaking.
2014 Mk7 GTI - Littco L500
Offline tweed
« Reply #2 on: 24 December 2012, 23:09 »
Check your wheel bolts just incase
Offline spudboy6
« Reply #3 on: 24 December 2012, 23:15 »
Nice one for that , got home had a look found the rear mount hiding away , although no movement in engine back and forth so leaving that be for now . the box mount i can put my hand on it and pull up on the box and the box moves (play in the mount ) also can see some oil from it , so will get a new box mount when all the days off are over and mr postman wants to deliver again .
on the wheel bolt issue will check it just incase i did put tyres on it recently so best check them now or i will worry every time i drive it until i do  :rolleyes:
