Author Topic: Quick conversion question- from 8v to 16v  (Read 3577 times)
Offline arran.concept
  • Yellow Colour Concept
« on: 24 December 2012, 17:35 »
Want to keep my colour concept shell but fancy some more go go. Tight budget, so was just wondering what parts I would need cheers
Offline 67buggers
Re: Quick conversion question- from 8v to 16v
« Reply #1 on: 24 December 2012, 17:50 »
Do a search and look for posts from murraymint he did a detailed list of parts needed for a 1.6 to 16v conversion, frim what little i know i think you will need to do the same amount of work as in his list
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
« Reply #2 on: 24 December 2012, 17:57 »
Nightmare searching trying to find stuff, heard its not as much due to it being already Gti 8v
Offline murraymint
« Reply #3 on: 24 December 2012, 17:58 »
Here's the thread buggers is talking about if you couldn't find it. I did buy a 16v for the conversion, but ended up doing that up instead  :grin:
http://www.golfgtiforum.co.uk/index.php?topic=232431.0
« Last Edit: 24 December 2012, 18:01 by murraymint »
josh
« Reply #4 on: 24 December 2012, 18:04 »
I've got a 8v Gti and want to convert to a 16v Gti
Offline murraymint
« Reply #5 on: 24 December 2012, 18:08 »
If you read on thru the thread I've gone on to write up a list for parts for a 16v conversion
josh
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #6 on: 24 December 2012, 18:24 »
Since its crimbo  :wink:
The engine, loom, ecu and exhaust would be all you 'really' need.
You can use your 8v flywheel, clutch and gearbox set up, the gearing will actually make it a little quicker off the mark too.
However, the 8v 020 boxes aren't that great with the lowly 115bhp getting put through them, never mind the 150bhp from the valver but in my opinion i think it should be ok.
Merry xmas  :smiley: :smiley:
« Reply #7 on: 24 December 2012, 18:29 »
Boss  :grin: cheers man, would my shafts and mounts be alright do you know Ben?
My 2L 8v has the 1.8 gearbox on and it makes good difference.
Offline tweed
« Reply #8 on: 24 December 2012, 19:11 »
Read the ducking thread!!!
Everything is in front of you so read it.
« Reply #9 on: 24 December 2012, 21:07 »
If you going to do it then fit a VR6 :smiley:
