Author Topic: help needed, poorly 20vt novice  (Read 987 times)
Offline sexydean123
« on: 23 December 2012, 14:28 »
hello everyone, i have a silver 2000model golf gti turbo,
i have plugged in a fault code reader and reads no codes ,
i can start the car from cold, drives ok, as soon as i turn it off and restart it, it cuts out,
i try and drive it and its cutting out and back on, almost impossible to move away,
i keep turning it on and off untill it will start with loads of revs, then i have to keep the revs up to move away and sometimes even then it splutters,
hope that makes sense
Offline Nino
Re: help needed, poorly 20vt novice
« Reply #1 on: 23 December 2012, 16:01 »
Hmm you tryed cleanin the TB?
Current - MK6 GTi Edition 35
Offline sexydean123
« Reply #2 on: 23 December 2012, 16:02 »
yes its electric with no cable, i just look it off and cleaned inside, i didnt take the electric part apart tho
Offline sexydean123
« Reply #3 on: 24 December 2012, 00:54 »
being curious would a bailey dump valve (dv26) cause this on a arz engine??
Offline Rob Zombie
« Reply #4 on: 24 December 2012, 09:28 »
Scrap that DV and get a Forge 007p recirc valve or the splitter and run as recirc...
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
