Author Topic: More issues  (Read 1623 times)
Offline gtigirlracer
More issues
« on: 23 December 2012, 12:30 »
After sorting out the engine cutting out problems I have no got another problem. I struggle sometimes to get it into first and second gear, when it seems to go into gear there is no power , seriously considering sending my little baby to car heaven   :cry:
Offline trog_nfs
Re: More issues
« Reply #2 on: 23 December 2012, 12:44 »
tbh I wouldn't have a clue what to do with one
Offline tweed
Re: More issues
« Reply #3 on: 23 December 2012, 13:12 »
What about other gears including reverse?
Has it just happened?
Has it been slowly getting worse?
I think you just need new linkage at this point.
Re: More issues
« Reply #4 on: 23 December 2012, 13:14 »
Hi, all the other gears seem fine , It's only started happening the last couple of days , today was just really bad though.
Offline tweed
Re: More issues
« Reply #5 on: 23 December 2012, 13:50 »
I think you will need is that kit trog posted and someone to fit it.
Offline Leon27
Re: More issues
« Reply #6 on: 23 December 2012, 16:55 »
If, when it gets into gear, it has no power do you mean you rev the car and the revs go up but the car doesn't move in relation or does the car  not respond to the accelerator pedal? i.e. the engine doesn't rev up?
Thinking you may have a clutch issue or a gear alignment issue plus something else :(
Re: More issues
« Reply #7 on: 23 December 2012, 18:01 »
The revs go up , had the RAC out and they said poss linkage/gearbox fault, play in gearbox linkage
Offline Len
Re: More issues
« Reply #8 on: 24 December 2012, 12:13 »
How did you sort cutting out?
www.sas.org.uk
www.the-ace.org.uk
