Author Topic: ok wanting a fault code reader  (Read 2518 times)
Offline dubpirate
« on: 22 December 2012, 18:21 »
my car is a 1993 mk3 golf 1.4 ryder abd engine
will it plug in
is it a 16 pin reader i need
any recomendations
thanks
Offline dubpirate
Re: ok wanting a fault code reader
« Reply #1 on: 22 December 2012, 18:49 »
ok so i have read post 1990 cars are 16 pin ust want someone to confirm b4 i purchase one thanks
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 22 December 2012, 20:02 »
It will be obd1 2x2 (4 pin) not obd2... you can still get readers (or a converter plug so you can use obd2 reader) they changed for Euro2 emission reg's in mid 94ish
Offline itavaltalainen
« Reply #3 on: 22 December 2012, 20:46 »
Strictly speaking Mk3 is not OBD2, it only got the OBD2 16-pin socket from MY95 on.
Protocol has not changed, just a different socket and a "modern" OBD reader will not work with them. You need a VW specific one, e.g. an AutoDia K409.
Adapters from 2x2 connector to 16 pin can be bought but if you got to scrappy and get yourself a new centre console you can just rewire the socket to 16 pin one.
Would not buy a cheap chinese copy, they are rubbish and you will suffer from timing issues on the USB <-> RS232 conversion before adapter converts it to TTL.
  • Back in a Mk3...
« Reply #4 on: 22 December 2012, 22:28 »
I just thought, If your local to me and get a 2x2 converter cable (I've lost mine somewhere) then I can try both my scanners for you (I have semi-full vcds too)
Offline dubpirate
« Reply #5 on: 22 December 2012, 22:35 »
Would a u281 reader work with an adaptor cable ??
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 23 December 2012, 00:42 »
It's what I've used on my past 3 mk3's without a hitch. Cheap, simple and effective.
Offline dubpirate
« Reply #8 on: 23 December 2012, 08:20 »
These are only £10 on eBay or are these the copies your on about cheers
« Reply #9 on: 23 December 2012, 13:42 »
As your fault code reader is a stand alone unit it cannot suffer from USB <-> RS232 conversion timing issues ;)
The background with Ebay cables:
Cheap "VAG COM" compatible cables from China quite often have cheap (a/k/a forged) FDTI USB-RS232 adapter chips which come with sh!t drivers... since Windows is poor with USB real time keeping it needs some good drivers and authentic chips, otherwise you won't get a connection.
I have built my own RS232 VAG interface (with a kit from ELV Germany, product code VDA100) and use a Brainboxes USB<->RS232 adapter to connect to it. Brainboxes converters are very good and made in the UK, so you can actually get support for them and they come with life time warranty... We use them at work for high tech devices.
