Author Topic: 1.4 abd coolant sensor change few questions  (Read 1190 times)
Offline dubpirate
« on: 22 December 2012, 17:08 »
hi again
i only changed the coolant not too long ago
now i need to do the coolant temp sensor which i have
when i remove the old one how much of the coolant will come out will it be all or not that much
cheers dan
Offline Bellend
Re: 1.4 abd coolant sensor change few questions
« Reply #1 on: 22 December 2012, 18:06 »
A fair bit will. Top it up and run it with the cap off squeeze all the pipes. Once it's up to running temp feel both pipes top and bottom of rad and make sure they are both hot to make sure the thermostat has opened. Give all pipes a final squeeze and top fluid to correct level and replace cap.
Basically it will come out til the level of the sensor. I.e any pipes above including the expansion tank.
Where all my moneys went.
