Author Topic: stereo loom chopped can i replace??  (Read 1049 times)
Offline dubpirate
« on: 22 December 2012, 17:07 »
hi
was wandering if this part of the loom is easily removable like plug and play as i have had cars that it is
thanks
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: stereo loom chopped can i replace??
« Reply #1 on: 22 December 2012, 17:51 »
Crimp some new pins on the wires and fit new connector housings.. job done.
If you can't do that then chop off connectors with 6" wire on them from car at breakers and solder/heatshrink those to your wiring.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 22 December 2012, 20:04 »
you could replace the loom but it won't be easy and you'll need to remove a lot of dash etc
this may help though?
http://www.golfgtiforum.co.uk/index.php?topic=74087.0
