Author Topic: squealy belt  (Read 1461 times)
Offline vw_golf_nutter
squealy belt
« on: 22 December 2012, 16:00 »
hi all,
probably a very simple stupid question to all of you but one of my belts keeps squealing when its wet. its so annoying, is this just something that happens or does something need adjusting?
thanks.
ps. its a mk3 cabrio 2.0
Offline Foreveryoungaus16v
Re: squealy belt
« Reply #1 on: 22 December 2012, 16:05 »
Is the undercarriage splash guard which protects the belts from getting wet missing from your car. How do your belts look? Dry and cracked or frayed - or fine?
163 BHP (TSR POWER RUN)
Re: squealy belt
« Reply #2 on: 22 December 2012, 16:10 »
Slight tightening would help. Also clean the pulley running surfaces  :wink:
Re: squealy belt
« Reply #3 on: 22 December 2012, 16:17 »
didnt know it had a splash guard, will have a look. all the belts were replaced about 3/4 months ago.
Re: squealy belt
« Reply #4 on: 22 December 2012, 16:22 »
Re: squealy belt
« Reply #5 on: 22 December 2012, 17:59 »
thanks, will have a look tomorrow. how do i clean the pulleys? do i have to take the belts off?
Offline tweed
Re: squealy belt
« Reply #6 on: 22 December 2012, 18:25 »
It will be power steering pump belt.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: squealy belt
« Reply #7 on: 22 December 2012, 18:42 »
The belt has probably stretched a bit seeing as it's not that old making it loose. Adjust it up and it should be better although they do have a tendency to slip quite easily when water goes anywhere near them.
The splashguards are ok but not the ultimate answer.  The 16v and TDI full under engine trays work more effectively.
