Author Topic: Another leak in the boot, almost fixed!  (Read 1033 times)
Offline bonny
« on: 20 December 2012, 21:30 »
ok so i had a water leak in my boot done the search & came up with the vents behind the rear bumper so i sealed them up but was still leaking  :rolleyes:
Also changed the rear light seals but still leaking  :shocked:
So tonight it was pi$$ing down i thought i would have a look to see where the water was coming from & it seems its running down from the seem & not the light seal or vents!
Golf mk4 non sunroof 5dr 2002
Any other advice to where it could be running down from???
Getting on my nerves this damp smell now  :rolleyes:
« Last Edit: 20 December 2012, 21:46 by bonny »
The more you pay The faster you go.....
Offline Dalo Harkin
Re: Another leak in the boot, almost fixed!
« Reply #1 on: 21 December 2012, 14:18 »
Have you checked the rear connection to the washer? - prone for not being tight enough.
Offline bonny
« Reply #2 on: 21 December 2012, 14:20 »
No i havnt where is it? To be honest i don't even use the rear wash spray!
Offline Dalo Harkin
« Reply #3 on: 21 December 2012, 14:40 »
Take the surround off the rear of the boot and you will see a tube attached to the mechanism - normally loose............... or come off
Offline bonny
« Reply #4 on: 21 December 2012, 19:26 »
Checked that & its already zip tied on  :grin:
