Author Topic: anyone else get frustrated by their tools!? well no more!  (Read 7290 times)
Offline whileoceanasleeps
  • patience comes to those who wait.
Re: anyone else get frustrated by their tools!? well no more!
« Reply #40 on: 02 January 2013, 11:44 »
would you guys say it's necessary to own a torque wrench and where would you most use one? i've never used one
Offline danny_p
« Reply #41 on: 02 January 2013, 19:54 »
if you need a torque wrench entirely depends on what you plan on takeing apart.
torques are specifyed for most bolts holding relativly inportant things together so of thesse things are more fussy than others.
things involving bareings  and large sealing faces a torque wrench is a good idea/nessesity . epenging on how good you are at judgeing torque.
a lot of bolts  like holding engeins and box / engine mounts wishbones ect   most people do up somewhere between tight and f**king tight
all the VW's have gone bar 1.
Offline bunj
  • www.bunjair.com
« Reply #42 on: 03 January 2013, 07:41 »
If your doing your own servicing and light mechanics then yes I'd say you need a tourque wrench.
When I first got my 1.8T I got my mechanic friend to do the cam belt and tensioner (as you do) no problem there. Anyone who's done this will know you need to remove the top engine mount to do this job. 3 months later my engine mount bolt to block failed and dragged the belt into the mount nearly ripping it into shreds!!
On inspection the thread was loose in the block ????
New engine mount, bolt set, cam belt and tensioner later ££??  It was tourqed to the correct rating but he'd forgot to do the extra 90 degree pull on each bolt (first time round) I check it every so often now and its minty moo but without a tourque wrench, a setting and the correct angle pull it only takes a bolt to work a little loose and bang.......
MK4 GTi 1.8T, Black magic, stage one Jabba, Forge Split, filter, sportex race pipe, lowered 25mm.
PS3 network: raebuns
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #43 on: 05 January 2013, 14:48 »
if you're looking for one Sealey have just announced a sale & the prices look good...
http://www.sealey.co.uk/PLPageBuilder.asp?id=26&method=mPromotionTitlesCurrent
For More Info Click To See;
VW BUSH
« Reply #44 on: 05 January 2013, 15:56 »
Cheaper torque wrenches must not be left with the spring loaded or used to undo, if you do then they become just a long ratchet handle.
Offline houston
« Reply #45 on: 05 January 2013, 20:12 »
i learnt that the hard way and broke a 7ft wheel nut wrench at work, went to change a tyre on a bus and forgot extension.thought the tw would be fine till the thing went crack and twisted.
nice £500 bill for accounts  :whistle: and a £100 tow for the bus
Offline JC
  • Back in the North.
« Reply #46 on: 05 January 2013, 20:14 »
to be fair, when have most people checked the calibration on there own torque wrench  :whistle:
and most will have left them loaded up at some point  :lipsrsealed:
Offline danny_p
« Reply #47 on: 05 January 2013, 20:29 »
have to have them checked all to often,  sadly there usally about f**ked then as well.
Offline JC
« Reply #48 on: 05 January 2013, 20:31 »
understandably knowing the grief you will give them danny  :laugh: :grin: :whistle:
Offline danny_p
« Reply #49 on: 05 January 2013, 20:43 »
i cant be that nasty to things ........  the passat is still alive  :shocked:  done some miles to
