Author Topic: repeaters or lights - Which wire  (Read 2141 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« on: 20 December 2012, 09:13 »
weather dependant I'll be fitting my newly painted us rub strip with lights...but my question is do I wire them in as side lights or repeaters...if the later which wire is it to splice them into :smiley:
« Last Edit: 28 December 2012, 22:40 by scarr89 »
Offline GTi_James
Re: repeaters or lights
« Reply #1 on: 20 December 2012, 09:15 »
wiring them into your sidelights if you dont want them as repeaters  :wink:
Offline scarr89
« Reply #2 on: 20 December 2012, 11:29 »
I will do. Just need to know which wires which.  :undecided:
Offline mcgee9t2
« Reply #3 on: 20 December 2012, 13:01 »
im wiring mine to the side lights, however not sure which wire it is either, so if you find out let me know.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 20 December 2012, 13:55 »
Get yourself a multi meter and see which wire is live when the sidelights go on. I'd personally have them come on when the ignition is turned on
Offline GTi_James
« Reply #5 on: 20 December 2012, 14:08 »
+1 didnt think of that
Offline scarr89
Re: repeaters or lights - Which wire
« Reply #6 on: 28 December 2012, 22:42 »
I do no have a multi meter. Could anyone give me the heads up on which wire to tap into for my soon to be newly installed US running lights please  :embarrassed: :smiley:
Offline beppe2672
« Reply #7 on: 29 December 2012, 01:21 »
If you want them to come on with the ignition, try tapping into one of the thick black/yellow wires in the back of your fuse panel, if you want them to come on with the sidelights, I believe pin 8 (-) and pin 10 (+) on the T10 connector on the back of your headlights could work, or find out which wire supplies the sidelights on the back of the lighting switch. If you want to be sure, make your self a test lamp to use instead of forking out for a multi meter (2 bits of wire attached to a bulb) to check the feed before you wire your lights in. Please don't blame me if stuff sets on fire and please don't use scotch locks, they're the devil!
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline beppe2672
« Reply #8 on: 29 December 2012, 01:28 »
Also it would be tricky wiring them up to your side repeaters. The change in resistance in the circuit caused be adding extra bulbs will change the rate the bulbs flash if the flasher is load sensitive (not sure if they are in these cars).
edit: just checked, the flasher is electronic, so shouldn't be load sensitive, but its only rated at 21 Watts, I wouldn't do it.
« Last Edit: 29 December 2012, 01:41 by beppe2672 »
Offline scarr89
« Reply #9 on: 29 December 2012, 14:30 »
Spot on, cheers mate. I'm going to go for when the ignition is turned on. Good idea with the bulb....What do you mean by scotch locks?  :undecided:
