Author Topic: Milage..  (Read 1227 times)
Offline Ralphy_GTI
Milage..
« on: 20 December 2012, 06:56 »
Ive had a engine replacement and my new engine is running at 70k whereas my dashboard says 150k, Is there a way to reprogram the dash to 70k?
Golf Mk3 GTI - Gone but never forgotten!
Golf Mk4 TDI - Back from the dead!
Offline Nino
Re: Milage..
« Reply #1 on: 20 December 2012, 07:14 »
I beleave it can be done with a vagcom?
Current - MK6 GTi Edition 35
Offline SI74
Re: Milage..
« Reply #2 on: 20 December 2012, 07:47 »
Yes it can be done but I wouldn't do it.      Why do you want to do it?
Offline xxChrisxx
Re: Milage..
« Reply #3 on: 20 December 2012, 08:41 »
The odometer indicates how many miles the vehicle has covered, not the engine.
Just consider fully the implications of wanting to do this.
« Last Edit: 20 December 2012, 15:39 by xxChrisxx »
Re: Milage..
« Reply #4 on: 20 December 2012, 13:41 »
I would leave the clocks as they are, just make a note of the engine change
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Milage..
« Reply #5 on: 20 December 2012, 13:57 »
As above. It will show up on MOTs and will put potential buyers off if you ever go to sell the car. It could also land you in a bit of trouble if you get pulled and a copper wants to be picky as it's essentially clocking
Also it can't be done with VAG COM, only VAG Tacho
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: Milage..
« Reply #6 on: 20 December 2012, 16:41 »
A car with 100k and a engine done 1k doesn't make a difference, so no don't change mileage as said above just keep record in with paperwork pref with receipt for engine if you can. You should also change engine number with DVLA.
Offline Ralphy_GTI
Re: Milage..
« Reply #7 on: 23 December 2012, 03:55 »
ok thanks for the helps guy  :smiley:
