Author Topic: EGR Delete Fitted (Now with Boost Gauge)  (Read 23713 times)
Offline Dizzie
  • Make friends with your fast
Re: EGR Delete Fitted (Now with Boost Gauge)
« Reply #30 on: 29 January 2013, 15:28 »
doesn't the butterfly in the EGR system also help reduce the judder you get when you turn the engine off?
how is that now this has been fitted? Tempted to fit 1 myself, but don't want violent shut offs :(
Mk4 Golf 150PD
Offline gt130dave
« Reply #31 on: 29 January 2013, 16:25 »
Just a quick question as i want to do this on mine, But by removing the EGR will this cause any damage
Offline Hoggy
  • Mk4 GT TDI 150.
« Reply #32 on: 29 January 2013, 18:42 »
Personally I haven't noticed a difference, some people do but mine is fine :)
None at all, its good to get rid of it, makes sure the engine is running a lot cleaner! :)
Offline gt130dave
« Reply #33 on: 30 January 2013, 06:12 »
Thanks Hoggy will need to purchase one now any ideas as your contact has sold out
Offline gt130dave
« Reply #34 on: 30 January 2013, 06:28 »
Nice job on the pod  :wink: just bought a delete kit a allard one £62 looks simple enough to do.
Where did you get the kit from m8
Offline Hoggy
  • Mk4 GT TDI 150.
Offline JimBR
« Reply #36 on: 03 February 2013, 18:19 »
Your coolant is way too full  :grin:
Offline Hoggy
  • Mk4 GT TDI 150.
« Reply #37 on: 03 February 2013, 18:36 »
Hmm yea you would think that..but thats where it has to be to stop the light coming on..not that it causes a problem at that level anyway :)
Offline sveed1.8T
« Reply #38 on: 15 February 2013, 21:11 »
I know that the 130pd and 150pd have a larger bore than the 115pd, but would the EGR delete (for them) bolt on to my 115pd? :huh:
I want to run 57mm pipe work to the intercooler, but little point if I have to purchase the 51mm bore EGR delete :undecided:
Offline Hoggy
  • Mk4 GT TDI 150.
« Reply #39 on: 15 February 2013, 22:00 »
Hmm this depends how the 3 bolt holes would line up..if they lined up then no problem :)
