Author Topic: Air con removal / smaller belt  (Read 6197 times)
Offline Gabriel2202
« on: 19 December 2012, 00:30 »
I am Looking to remove my air con system and wandering if anyone knows what belt size i can use for a 1.8t aum? Or even better a reg I can use at Ecp to get it? (Is it an agu that has no a/c)
Will there be any problems in terms of warning lights and will there be enough tension in the belt seeing as the a/c pulley is removed between power steering and alternator pulleys?
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline rockmonkey69
Re: Air con removal / smaller belt
« Reply #1 on: 19 December 2012, 00:52 »
There will be no problems with warning lights
Offline wotavudunn
« Reply #2 on: 19 December 2012, 00:56 »
just ring euro car part ask the for a aux belt for your mk4 golf 1.8t and its a non air con model, there about £9-£13.
Offline Gabriel2202
« Reply #3 on: 19 December 2012, 08:52 »
Cheers guys  :smiley:
Does anyone know if it will slip or not as the belt won't have as much contact with the alt and p/s pulleys as the a/c pulley is no longer there to pull the belt in, if that makes sense?  :huh:
Golf IV 1.8T AUM
Golf V GT TDI PD170
« Reply #4 on: 19 December 2012, 10:25 »
It will be no different from the non aircon version from factory. The slack is taken up by the tensioner anyway. Belt wrap is more or less the same. If you look where the aircon pump is and imagine it gone with a shorter belt you can quite easily see how the belt should run.
« Last Edit: 19 December 2012, 10:29 by rockmonkey69 »
Offline Gabriel2202
« Reply #5 on: 19 December 2012, 10:43 »
Yeah the routes fine i was just worried about belt wrap, thanks man  :smiley:
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline davemk4
« Reply #6 on: 19 December 2012, 16:30 »
Im after a working aircon compressor if you take it off soonish let me know please
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Prawny
  • R-tech power!!!
« Reply #7 on: 20 December 2012, 13:56 »
I removed my aircon too, just asked for a non aircon aux belt at TPS. AGU/AUM belts are the same. it's aircon or non aircon that's the difference.
Belt wrap is SLIGHTLY less, but I've not had any issues with it yet and no audible slip at all
Offline wotavudunn
« Reply #8 on: 20 December 2012, 21:17 »
my air con went soon as i brought my car
