Author Topic: VR6 Backfires When Cold, Any Suggestions?  (Read 1876 times)
Offline MK4D4VE
« on: 18 December 2012, 20:08 »
Hi all
I have a problem with my VR6, in which when it fires on cold start i get one backfire as it starts, and it is quite loud!
The car itself runs fine when started, and runs absolutely fine in the warmer months and only seems to have developed this fault since it has been cold, whats more the revs don't idle too much below 900-1000 rpm as well.
Anyone have any suggestions?
I am picking my new car up in January so don't really want to spend too much money on it, will be selling it very cheap soon.
Thanks
David
Golf MK4 1.8 20v GTI
Offline leigh_harty
  • Audi AGU
Re: VR6 Backfires When Cold, Any Suggestions?
« Reply #1 on: 18 December 2012, 20:23 »
Sounds like an over fueling issue. does it fail to start then bang?
Dont lose your dinosaur!
Offline tweed
« Reply #2 on: 18 December 2012, 20:38 »
Fuel pump relay would be my first try
VW BUSH
« Reply #3 on: 18 December 2012, 21:08 »
Go with what's been suggested first, I've had this caused by a blocked/duff injector before.
Worth plugging into a code reader.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #4 on: 18 December 2012, 21:22 »
coilpack
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline MK4D4VE
« Reply #5 on: 18 December 2012, 21:32 »
A whole host of possibilities!
If i turn the key to start it, it will die unless i start it with a the accelerator pushed a little to give it a little rev, then it stays started, slightly higher revs but goes bang as well.
Offline F17BAD
« Reply #6 on: 18 December 2012, 22:18 »
coilpack coilpack coilpack
Offline MK4D4VE
« Reply #7 on: 18 December 2012, 22:50 »
You seem very confident?
Offline MK4D4VE
« Reply #8 on: 18 December 2012, 22:55 »
And I assume you mean ignition coil pack?
Offline leigh_harty
  • Audi AGU
« Reply #9 on: 19 December 2012, 08:20 »
Mine would fail to start and the exhaust would replicate a shotgun  :grin:
But I had/have fuel pump issues. Coilpack anf spare work and brand new genuine pump relay
