Author Topic: juddering under braking  (Read 1380 times)
Offline Vdub_nut_rich
  • MK3 Gti i love this car
« on: 18 December 2012, 16:48 »
Hello
i have another problem on my MkIII golf again, this time when braking.
i get a juddering from the front wheels, i think it could be warped disks but its only just started last week.
any ideas guys
thanks Rich :sad:
Offline Luke1981
Re: juddering under braking
« Reply #1 on: 18 December 2012, 17:00 »
It will be one of three problems - Warped discs, fcucked pads or sticking calipers. Take your wheels off and check if the discs for high spots and uneven wear on the pads.
MK IV GT TDI 150 PD / MKII CADDY SDI
« Reply #2 on: 18 December 2012, 17:10 »
thanks i'll check it out
cheers
VW BUSH
« Reply #3 on: 18 December 2012, 21:05 »
do you feel it in the pedal?
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 19 December 2012, 10:05 »
Most likly you wilk feel it in the steering & you will see the steering vibrate (been there) if so then warped discs. As previously said take the discs off & check them on a flat surface
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline vwwvgolf
« Reply #5 on: 20 December 2012, 12:37 »
check wheel bolts tight too
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 20 December 2012, 18:47 »
This aswel
*****MK4 GTI T*****
Offline Foreveryoungaus16v
« Reply #7 on: 20 December 2012, 18:53 »
Wheels might need balancing as I had same prob :angry:
163 BHP (TSR POWER RUN)
