Author Topic: golf 1.8t TURBO flutter after N249 bypass and sai removed  (Read 2231 times)
Offline vrsjaw
hi remove the valves and sai and egr,,,now am gettng turbo chatter or flutter as they say,,av noticed my car is abit down on to en power,,,a checked all pipes,,av put my standard dv back on and yesturday i put the valves back on that are near dip stick and its still doing it...my car has stage 2 map with all the mods to suit...any help would be greatfull
Offline Chris.
Re: golf 1.8t TURBO flutter after N249 bypass and sai removed
« Reply #1 on: 17 December 2012, 02:51 »
Did you run a pipe straight from inlet to DV?
Click For Build Thread
Offline vrsjaw
« Reply #2 on: 18 December 2012, 01:00 »
yes i did, dv to inlet
Offline rockmonkey69
« Reply #3 on: 18 December 2012, 01:02 »
Have you got a picture showing what you have done?
Also did you fit resistors in place of SAI and other valves removed?
Offline vrsjaw
« Reply #4 on: 18 December 2012, 01:03 »
.,,,,yes mate
Offline vrsjaw
« Reply #5 on: 18 December 2012, 16:21 »
yes i fitted resistors but av put my stuff back on apart from sai and agr, and left 1 resistor for the sai pump, my car is still chattering,,,cheers
Offline Dalo Harkin
« Reply #6 on: 18 December 2012, 20:46 »
how many resistors and what OHM etc did you use?
did you also rip the hard lines out?
Offline Chris#101
« Reply #7 on: 18 December 2012, 21:04 »
Mine did exactly the same when I bypassed the N249 valve and I couldnt get to the bottom of it, checked rechecked and checked for vacumm/ boost leaks to which I found none :huh:
http://www.youtube.com/watch?v=O83h9a_K3GY
How ever after changing my hotside IC pipework from 1.75" to 2.5" it dissapeared and blows off as normal. So I can only assume that I must of 'un disturbed' something when putting the larger pipework in  :laugh:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline vrsjaw
« Reply #8 on: 18 December 2012, 22:39 »
i think they were 330 and 10 watt...used 4 of them,but as said only one now..
Offline vrsjaw
« Reply #9 on: 18 December 2012, 22:42 »
removed all the pipes when i did it..but as said av fitted all apart from sai pump and egr...sounds mad when chattering but it cant be good for the turbo....my mate did his months ago and his is fine,,,,could just be that some cars like it and some dont
