Author Topic: APX HEAD ON AGU BLOCK  (Read 1015 times)
Offline shaft69
« on: 16 December 2012, 23:20 »
My friends Audi tt bottom ends knocking, I've agu engine in golf I'm breaking. Be ok put apx head on agu block???
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline rockmonkey69
Re: APX HEAD ON AGU BLOCK
« Reply #1 on: 17 December 2012, 00:14 »
It's interchangeable, are you planning to fit the vvt as well? Or keeping the agu cam chain tensioner? A lot of people are going vvt on the agu now with the use of the later wide and ecu.
Offline shaft69
« Reply #2 on: 17 December 2012, 11:12 »
It's Wreg not sure if that early has vvt!!! Will check tho will be straight swop over just his bottom ends knackered and I have this agu spare only on 90k miles with history.
184 Wallgate, Wigan
WN3 4AL
07966492823.
« Reply #3 on: 17 December 2012, 11:26 »
O right I follow you, I thought you was looking to change the head on the agu. It was far past my bed time when I replied  :grin: ignore me lol
Yes it will bolt on fine  :cool:
Offline ReDBull
« Reply #4 on: 17 December 2012, 19:24 »
It will fit but he'd be better off fitting the whole engine.  As he'd benefit from the large port head and higher CR.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
« Reply #5 on: 17 December 2012, 19:44 »
Apples and oranges. Some prefer higher compression some prefer lower compression, all a matter or build. Both are available in aftermarket form for the 1.8t and both came from factory.
