Author Topic: Front strut trouble  (Read 2037 times)
Offline theclash
Front strut trouble
« on: 16 December 2012, 21:53 »
The hex keyway on top of my front strut is rounded as anyone got any suggestions  other than gripping it with mole grips
Offline itavaltalainen
Re: Front strut trouble
« Reply #1 on: 16 December 2012, 22:25 »
pneumatic driver on the nut and it might come loose.
other than that... you wanna replace the strut or just top mounts?
if you're gonna change struts then hammer in a 10mm allen key or otherwise torx (thin enough so you can still get 21mm spark plug socket on to undo nut). that should do the trick....
Offline theclash
« Reply #2 on: 16 December 2012, 22:34 »
I bought the strut 2nd hand and stripped it down using impact gun
Iam going to put new top mounts on and fit it to the car just worried about fitting it without being able to stop it spinning because of the rounded off Allen key way
« Reply #3 on: 16 December 2012, 22:45 »
you should be able to tighten it up with impact gun.... other than that cut in slot and use large flat screwdriver, though i doubt you'd be able to stop it spinning with that. :D
not gonna comment on 2nd hand struts though  :whistle:
Offline Diamond Hell
  • Opinions я Us
« Reply #4 on: 17 December 2012, 13:13 »
Fitting one strut at a time?
Silly idea - get a pair of matched ones: they do quite a lot.  :rolleyes:
Offline theclash
« Reply #5 on: 17 December 2012, 21:50 »
Never thought of that  :wink:
Good job I bought all 4 ....
.next silly comment !
Offline jakethesnake180
« Reply #6 on: 20 December 2012, 08:32 »
I had the same problem on my 16v, tried everything on the nut and shock but no joy.
I ended up covering the engine and grinding off the flat ring of the top cap,
It's shaped like an upside down top hat, I ground off the brim!
The strut will then drop through the hole in the  chassis leg and you can get it in the vice etc,
A new top cap from VW was about 7 quid
Just make sure you cover the engine with something flame retardent, especially the metering head
  • Opinions я Us
« Reply #7 on: 20 December 2012, 12:32 »
Maybe look to your own stupid posts before endeavouring to lampoon others:
This implies you purchased one strut, which was secondhand.
Got any more stupid comments you want to make?
