Author Topic: Paint chip  (Read 1790 times)
Offline Snooze
Paint chip
« on: 16 December 2012, 20:28 »
My sister opened my rear door in to my steel driveway gate today. Brilliant!  :cry: It took the paint off the rim of my door about 1cm long.
A bit of touch up paint will sort this wont it? Cheers
« Last Edit: 16 December 2012, 21:07 by Snooze »
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline Murrayedition35
Re: Paint chip
« Reply #1 on: 16 December 2012, 20:40 »
Best to get it covered up with some touch up paint first..it won't sort it, you might need to get someone to do a proper job... :smiley:
Offline joe6
Re: Paint chip
« Reply #2 on: 16 December 2012, 20:51 »
If it is just the edge then touch up paint should work and not show if done carefully. Pack comes with colour and clear tubes. Temperature is important to get the paint to run properly and cure. Pinch the wifes hairdrier to warm the area and then cure the paint :wink:
Offline Steve30
  • Ed30 .
Re: Paint chip
« Reply #3 on: 17 December 2012, 18:24 »
Top advice there mate, if you want to sorted try ringing chips away i'm sure they have someone working in your area I've used them a few times results are very good. :wink:
Tiguan quicker than the Golf
Offline avalon
Re: Paint chip
« Reply #4 on: 20 December 2012, 12:32 »
Last time I had any dealings with Chips Away [3 stone chips on bonnet of an Alfa] they wanted to paint the whole bonnet!
Ava
GTi DSG 5 Door Candy White [MY11]
