Author Topic: golf 1993 1.4 temp guage faulty  (Read 4300 times)
Offline dubpirate
« on: 15 December 2012, 16:04 »
hi guys
bought another mk3
the temp guage seems to only raise 2mm above the needle or it may not move at all
any ideas temp is actually fine
cheers
Offline Luke1981
Re: golf 1993 1.4 temp guage faulty
« Reply #1 on: 15 December 2012, 16:57 »
Sounds like a knackered temp sensor. Not expensive to fix and easy to fit.
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline dubpirate
« Reply #2 on: 15 December 2012, 17:04 »
any chance of a part number or ebay link
think its abd engine
Offline Luke1981
« Reply #3 on: 15 December 2012, 17:51 »
No idea what the part number is, try euro carparts and type in your vrm into their search engine.
Offline itavaltalainen
« Reply #4 on: 15 December 2012, 18:25 »
What do you mean temp seems OK? ;)
I bet it's not the sensor but thermostat. Does temp go up at all when you idle it for a few minutes?
I've posted a photo here before, it's from a different engine but temp sensor characteristics are same; just measure with Ohm meter (cheap 3£ ebay multi meter will do)
If it matches this then sensor is fine.
Offline dubpirate
« Reply #5 on: 16 December 2012, 08:47 »
I have done the thermostat first thing I tried by temp seems fine it dosnt run hot over heat etc
