Author Topic: Clocks  (Read 1411 times)
Offline Mouse
Clocks
« on: 19 July 2005, 23:01 »
heya just got a mk1 gti yesterday.. and was wondering what the yellow stick that u can twist to 1 or 2 does it sits in the top right of the clocks,
cheers
Offline gibby
Re: Clocks
« Reply #1 on: 20 July 2005, 09:08 »
Is it the MFA (trip computer) ?  :undecided:
......now officially dubless.
Offline Mouse
Re: Clocks
« Reply #2 on: 20 July 2005, 19:55 »
its the yellow switch in the top right hand corner.
Offline gibby
Re: Clocks
« Reply #3 on: 20 July 2005, 21:18 »
 :undecided: Never seen one of those before so I really don't know. Anyone else ?  :undecided: Doesn't look like a standard bit to me but I could be wrong.  :undecided:
Offline micab
Re: Clocks
« Reply #4 on: 20 July 2005, 22:38 »
it`s normal, standard switch in MFA clocks, in european version this switch is white.....but I also don`t know for what it is  :undecided:
I come from Poland and my english istn`t so good....
best regards ;)
golf GTI EDITION `94
golf GTI `82 white
golf GTI `82 black - for parts
mercedes w115 200d `75
Offline black_cabbie
  • If they don't have a golf in heaven I am not going
Re: Clocks
« Reply #5 on: 28 July 2005, 11:06 »
This is the MK1 GTI campaign cluster.
The switch between 1 and 2 is the trip and total mode.
Mode 1 resets the MPG, average speed etc every time the engine is out for a few hours.
Mode 2 needs to be reset manually. Select either mode and then twist it a bit more in either directions and hold it there until the screen goes blank. It is now reset.
Use the button on the stalk to cycle between the screens.
There are also hidden menus that can be seen be keeping the button on the stalk pressed as you do this. Turn the key to the on position, off and then on again. Release the button and you are now in the hidden menus which display some usefull info like instant MPG, digital speedometer, digital tachometer and some other crap which are identifications for the year of the car, upper speed limit etc.
1.8L 8V Digifart, AMS chip, Kent 270 camshaft, TT Adjustable Cam Gear, Supersprint Header with supersprint catless system, BMW AFM, Adjustable FPR. G60 Green 23lb injectors coming soon.... =)
Offline Mouse
Re: Clocks
« Reply #6 on: 06 August 2005, 17:07 »
nice1 thanx alot  :smiley:
