Author Topic: ABS Light  (Read 968 times)
Offline CM690
  • Golf MK4
ABS Light
« on: 14 December 2012, 21:39 »
I noticed today a bit of a weird noise and then my brake pedal went funny. Ever since the ABS light has been on constantly, I need the car for work all weekend so is this safe to drive on?
Scanned it with one of those ebay handheld vag-coms and it's the front left sensor apparently? Are they an easy change?
Offline Luke1981
Re: ABS Light
« Reply #1 on: 14 December 2012, 22:28 »
From previous reading it can be an expensive job to sort the abs sensor!
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline CM690
  • Golf MK4
Re: ABS Light
« Reply #2 on: 14 December 2012, 22:36 »
Oh great :grin: Thats all I need at this time of year
LakerLover
Re: ABS Light
« Reply #3 on: 14 December 2012, 23:52 »
This wont help but thought id put it on here as its the same subject!
When the front of my car is jacked up with the ignition on, i spin the wheels manually and the ABS kicks in. No light on dash or anything!  :shocked:
Is that normal??
LakerLover
Re: ABS Light
« Reply #4 on: 16 December 2012, 12:32 »
Any help with this ABS (Another Brother stuck)   :grin:
Offline djmagpie
Re: ABS Light
« Reply #5 on: 16 December 2012, 22:29 »
really eazy 2 change 10 min job :)
1.8t agu,,Bora Vents,,Cai,,Vr6 clutch/G60 flywheel,,forge dump valve,,jom coilovers,,eibach front and rear arbs,, 15mm front 20mm rear spacers ,,3" downpipe & decat..sportex 4"oval exhaust
