Author Topic: Vag com  (Read 6606 times)
Offline jonesltd
  • MK7 R
Vag com
« on: 12 December 2012, 17:12 »
Does mk4 blue lead fit mk6? :undecided:
If you cant find it......Grind it
Offline Ess_Three
Re: Vag com
« Reply #1 on: 12 December 2012, 17:35 »
Blue what?
VCDS lead?
Genuine or copy?
The Mk4 wasn't CAN-Bus, so although you may be able to read certain values, unless it's a CAN-Bus compatible cable, you'll not be able to change anything.
If it's a CAN-Bus compatible lead, you may be lucky.
..but gaining motorcycles.
Offline jonesltd
  • MK7 R
Re: Vag com
« Reply #2 on: 12 December 2012, 19:43 »
All I know is its a few yrs old off eBay about 18 pound and some guy on here gave me the program?
Offline Ess_Three
Re: Vag com
« Reply #3 on: 12 December 2012, 19:48 »
It's unlikely to work.
Try it at your own risk...it carries the usual risks associated with copy cables.
